L3240 Rear Remote Problem
/ L3240 Rear Remote Problem #1
stroker_ace
Texas
Kubota M6060HDC
I am looking for some help in troubleshooting a rear remote issue I am having. I have a 7 ft. pull type disc with a double acting cylinder on it to raise and lower the transport wheels. The first time I used this implement, the wheels would raise and lower just as they are supposed to. As I continued to use the disc, the cylinder began to extend slower and slower. After using it for about 1 hr, the cylinder will not extend to raise the disc off the ground. If I let the tractor sit for approx. 30 minutes, and the cylinder will go back to working, just not very fast. All other hydraulic functions work as normal, including the loader and 3 pt. I checked the level of the fluid and changed the fittings on the end of the hydraulic lines going to the cylinder. I have also changed out the cylinder on the disc and this problem still exists. Any ideas as to what might be happening?
