L3240 brake lights
/ L3240 brake lights #1
orangeandgreen
kentucky
Kubota L3240 JD 1025R
Do some models of the L3240 have rear brake lights that work? I have an open station L3240 and noticed double filament bulbs and 2 "hot" wires going to the lights in the back of the fenders. The "dim" running lights come on with the light switch, but don't get the "bright" with any combination of brake/ parking brake/lights on/lights off. Just wondering if they aren't working, or not "supposed" to work, just common components with a model that has this feature?
Do the cab models have brake lights? Just wondering
Thanks
/ L3240 brake lights #2
cab models have Brake lights, running lights, emergency 4 way flashers and turn signals... no reason the open station could not have the same.
/ L3240 brake lights #3
Mine function as Kenny stated and its an open cab. Maybe check the fuses and wired under the fenders. One of mine had been pulled loose.
/ L3240 brake lights #4
Cab model's don't have brake lights.
/ L3240 brake lights #5
On my L3940 the double filament bulbs are for 4 way flashers. Not sure if I've ever saw brake lights on a tractor.
Keefer
My 4ways and turn signals flash the yellow lens (single filament) bulbs. The red lens (double filament) bulbs only light with the headlight switch.
/ L3240 brake lights #7
My factory Cab L4200 Has Brake lights... Every other cab Kubota I have seen had Break lights. Red lights on both right & left sides when ever brakes are applied...
That is why I would suspect the open station tractors could also have brake lights.
/ L3240 brake lights #8
Lots of tractors have brake lights. Example my open station Kioti. I know this does not answer the specific question about the 3240 though.
/ L3240 brake lights #9
Just checked my L3940HST open station. 2 wires going to red bulb/lens. No brake lights. Only running lights. Philip.
2007 FORD EXPLORER (A65643)
2007 FORD EXPLORER...
2010 John Deere 4720 (A64126)
2010 John Deere...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
66in. Skid Steer Bucket (A65640)
66in. Skid Steer...
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
4021 (A59228)
4021 (A59228)
