L3240 and B3030 Independent PTO?
   / L3240 and B3030 Independent PTO? #1
PSDStu
Platinum Member
Marianna, FL
Kubota, M7060 HDC12, L4060 HSTC, RTV 1140
I noticed that both tractors have an Independent PTO, but the L3240 has a "Master Clutch" pedal and the B3030 has no clutch pedal.
Whats the purpose of the Master Clutch pedal on the L3240 if it has an Independent PTO?
Is the clutch pedal used the same way as a Live Continuous PTO clutch is used.....ie... to feather PTO engagement?
Stu
   / L3240 and B3030 Independent PTO? #2
Stu
I guess you could feather the PTO. My 3940 is very smooth if you move the lever slowly. I use the clutch mostly for starting and emergency PTO stop.
   / L3240 and B3030 Independent PTO? #3
The way I understand it is the clutch allows you to disengage the transmission during a cold start, putting less initial strain on the equipment until the oil is circulating properly. I hold the clutch for a minute or two, until the engine smoothes out a bit, then let it out to continue the warm up. I am sure it is useful for babying the PTO as well, but haven't had the chance to use mine yet. Too cold! :)
   / L3240 and B3030 Independent PTO? #4
You can certianly here the load when letting the clutch out on a cold tractor !!!!!!:eek:
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
New Long Forks (A53002)
New Long Forks...
