Price Check L3200 HST 4WD R4
   / L3200 HST 4WD R4 #21
No hay here. I did move around 100+ tons of dirt. It will pick up the back end of my Jeep and travel with it. I think the hay bales may be a problem. Because the COG would be front pretty far.
Not with the right amount of weight on the 3 pt hitch.
   / L3200 HST 4WD R4 #22
Sorry. Knew what I meant, but didn't communicate it clearly. What I wanted to say was the center of the LOAD would be pretty far away from the tractor (making it quite a bit forward of where the lift rating is calcluated). A 100 pound load would be too much for a 1,200 pound rated loader to pick if it was far enough away from the tractor.
   / L3200 HST 4WD R4 #23
OK, that makes sense.
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2004 Ford Explorer Sport Trac Pickup Truck (A56858)
2004 Ford Explorer...
2008 Dodge Ram 1500 Single Cab Pickup Truck (A55973)
2008 Dodge Ram...
