Price Check L3200 HST 4WD R4
   / L3200 HST 4WD R4 #21
No hay here. I did move around 100+ tons of dirt. It will pick up the back end of my Jeep and travel with it. I think the hay bales may be a problem. Because the COG would be front pretty far.
Not with the right amount of weight on the 3 pt hitch.
   / L3200 HST 4WD R4 #22
Sorry. Knew what I meant, but didn't communicate it clearly. What I wanted to say was the center of the LOAD would be pretty far away from the tractor (making it quite a bit forward of where the lift rating is calcluated). A 100 pound load would be too much for a 1,200 pound rated loader to pick if it was far enough away from the tractor.
   / L3200 HST 4WD R4 #23
OK, that makes sense.
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
2013 Ford Edge (A54815)
2013 Ford Edge...
2012 DRAGON PRODUCTS CRUDE TRAILER (A58214)
2012 DRAGON...
