L3200 3rd function build
/ L3200 3rd function build
1 12v 10gpm OC DA solenoid valve
9-6136 $128.15 ea
1 DO3 Subplate
9-5883-1 $35.95 ea
2 Hirschmann connectors
11-2457 $4.80 ea
3 JIC 8M x SAE 6M 90 elbow
9-6801-8-6 $2.40 ea
3 1/2" npt quick coupler
928 $17.95 ea
6 JIC 8M x 1/2 NPT connector
9-2404-8-8 $1.60 ea
3 JIC 8M x JIC 8F swivel 90 elbow
9-6500-8-8 $2.50 ea
1 JIC 8M x SAE 6M connector
9-6400-8-6 $1.50 ea
3 3/8" x 18" JIC 8F x JIC 8F Hose
931-2218 $10.95 ea
2 3/8" x 84" JIC 8F x JIC 8F Hose
931-2284 $20.95 ea
1 3/8" x 48" JIC 8F x JIC 8F Hose
931-2248 $16.95 ea
3 3/8" two wire clamp
9-A2-18-D $3.30 ea
Total $354.95
John deere joystick ordered from greenpartstore.com
2 LVA12162 NUT $0.76 EA
2 37M7356 SCREW $0.82 EA
2 37M7355 SCREW $0.76 EA
2 21H1486 SCREW $1.10 EA
1 LVU16650 GRIP. $3.70 EA
1 LVU16701 GRIP $18.43 EA
1 LVA17501. WIRING HARNESS $53.77
TOTAL $79.34
It was around $6 to ship it. If anyone uses this be aware that the switches in this are only rated for 0.1 amps and the solenoid valve pulls around 3 to 3.5 amps. I had to solder new switches in finding out the hard way. I just used some automotive type relays and sockets I sourced from amazon. The relays actually pull more than the switch is rated for but I haven't had an issue as of yet. The relays seem to pull around 0.15 amps to engage them. I tested them all and installed the lowest of the bunch.
/ L3200 3rd function build #24
WOW! Very thorough. Thanks. You put a lot of thought into the design. Well done.
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
Challenger MT 700 Series Service Manuals Vol. 1 and Vol. 2 (A63117)
Challenger MT 700...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-150...
New 10' Cattle Working Chute (A62679)
New 10' Cattle...
