L3130 underpower problems Part Deux!!
   / L3130 underpower problems Part Deux!! #1
ramon49
Bronze Member
oregon
L3130
This is a legitimate post and I'm not a spy/clone/ company stooge/ and I don't like my L3130... Sorry! Had a specialist take the tractor for a pace test and results due this week. Seems the black smoke increases while RPM's decrease and the loader is cycled up or down.
   / L3130 underpower problems Part Deux!! #2
Ramon,
You'll find out what's wrong with it soon.
Did you check the fuel filter? A friend of mine has a combine that did basically the same thing a couple of years ago and it turned out to be a clogged fuel filter. Just a thought.
   / L3130 underpower problems Part Deux!! #3
Exactly how many threads are needed here to discuss one problem?
   / L3130 underpower problems Part Deux!! #4
Hi Philc,
Well I really don't know, we have heard alot from the other threads, but now it sounds like Ramon is getting a better diagnosis.
We all know the symptoms of Ramon's tractor. Ramon's tractor has been in the shop, which is similar to a general practitioner, now he's had a specialist to look at it. I believe he is getting one step closer to restoring the power of the L3130.
My L3130 GST with the LA 513 has enough power. If Ramon lived near Augusta GA I would like to visit him and take a look at his tractor. I would probably trade with him straight up so I could have a HST, if he would do that.
Hope he gets it fixed.
OK! here's what the problem was. Foreign debris in the fuel tank restricting the flow of fuel...... It now seems OK! Don't want to speak too soon!
philc,
Stop reading and go to the next one, who died and left you boss!!!
ramon
A big thanks to those who helped and got close to the problem. To those that were arrogant and mean spirited I forgive you, I'm so happy I could just Sh.......
   / L3130 underpower problems Part Deux!! #9
I am sure glad that you found the root of the problem and will be happy with the machine now. Some times it is a simple solution to something that seems major.
   / L3130 underpower problems Part Deux!! #10
Interesting. A Kubota L4850 we have had that issue. A wasp (mud dobber) had made a nest in the diesel can spout and consequently, the little larvae thing as well as the mud ended up in the tank. It starved the engine which did not exhibit your symptons, it simply ran like it was on only 3 cylinders, it has 5. Anyway, I really hope that is your issue. Best wishes.
2018 DODGE RAM 5500 HD LUBE TRUCK (A50459)
2018 DODGE RAM...
2004 Ford F-750 Crew Cab Wrecker Tow Truck (A48081)
2004 Ford F-750...
2018 Ford F-550 4x4 Summit 4416 Crane Mechanics Truck (A48081)
2018 Ford F-550...
2015 Ford F-750 Truck, VIN # 3FRXF7FK4FV740779 (A48836)
2015 Ford F-750...
2004 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
VOLVO MT2000 MILLING MACHINE (A50458)
VOLVO MT2000...
