L3130 underpower problems Part Deux!!
   / L3130 underpower problems Part Deux!!
I remember him saying they dyno tuned and it's in spec, only assumed it was 24hp! The problem is gone and I'm ripping up Mother earth. There are SYSTEMIC quality problems for sure with kUBOTA...
   / L3130 underpower problems Part Deux!! #32
Now that its running correclty....You'll have to tell us your revised opinion after running it a while.
Mine is that its not a powerhouse but does the job well. If I had to mow in hills a lot I'd want a couple more PTO HP.
CT, I have 52 hours now, setting telephone ploes and running barb wire. Tried post hole drilling thru Hard Pan and really miss the DRAFT function.. Had to pay a BOBCAT to drill the end posts. I say at this point the tractor (won't say underpowered) is showing it is indeed light in the HP. Guess I have to wait till next year to sell to my son in law...Then I'll get something similar to a D8..
   / L3130 underpower problems Part Deux!! #34
"Tried post hole drilling thru Hard Pan and really miss the DRAFT function.."
While the draft funtion is optional, it would do nothing to aid in drilling post holes. Either a hydraulic down on the PHD itself like I have or a loader mounted, hydraulic auger motor would certainly remedy this issue. Hardpan smard pan, good teeth and some weight will eat hardpan.
   / L3130 underpower problems Part Deux!! #35
ramon49
If you need a D8, then you way underestimated your needs when you bought the L3130.
Lewis
   / L3130 underpower problems Part Deux!! #36
Lewis, do you think you could take the diesel engine in a CAT D8 and couple it to the L3130? /forums/images/graemlins/smirk.gif
   / L3130 underpower problems Part Deux!! #38
The 14 cylinder version might require a little shoehorning to get under the hood, but if my math is correct, the motor/tractor should be about 42lbs/HP!!! That kind of ratio should be able to make even the most power hungry tractor operators happy.
   / L3130 underpower problems Part Deux!! #39
102 RPM might be a limiting factor, too. /forums/images/graemlins/grin.gif
   / L3130 underpower problems Part Deux!! #40
I would also suggest checking the air pressure in the tires. They will need the extra PSI.
1261 (A50490)
1261 (A50490)
2010 Chevrolet Silverado 3500 Utility Truck (Diesel), VIN # 1GB7CZB60AF108861 (A48836)
2010 Chevrolet...
2021 CATERPILLAR 305E2 EXCAVATOR (A50458)
2021 CATERPILLAR...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
RING 3 STARTS HERE @ 9:30 AM (A50460)
RING 3 STARTS HERE...
(2) Sumitomo 11.00 R22 Tires (A48837)
(2) Sumitomo 11.00...
