L3130 Kubota problem
/ L3130 Kubota problem #1
nue2farm
Douglas County, Missouri
Kubota 3130
My five year old kubota started losing power and stalling while I was bushhogging. Let it sit for a while and it seems to run normally for a little while then it loses power again.:confused2:
I checked what little I knew to check so I need help, any ideas will be appreciated. Thanks
/ L3130 Kubota problem #2
Most manual say to check air filter also fuel filter..more so when operating dusty etc. use.
/ L3130 Kubota problem #3
Basics 1st....Air filter and fuel filter...could also be heat related so check the rad isn't blocked..good luck.
/ L3130 Kubota problem #4
Did you just put "new" fuel in it?
Maybe the "new"fuel is bad?
or a fuel system blockage of some sort.
tom
Thanks for the suggestions. These are the things I have tried. I suspect the fuel, I did just get a delivery to my small farm tank (75 gal.) The driver did not purge the hose, that I noticed, after filling the unleaded gas tank. I thought a fuel problem would be an "all the time" problem. This happens after 30 to 60 minutes of bush hogging... losing power and stalling. Thanks for the help though
/ L3130 Kubota problem #6
Is it overheating?
Not overheating, by the temp guage. I talked to a neighbor, retired diesel mechanic, he told me to get the contaminated fuel out of the tractor and try known fresh fuel to see what happens. I drained the tank went to the store, 10 miles away, got 6 gal #2 fuel, put it in and everything seems ok now.
I called the fuel supplier, told him what was going on. He said they would be out this week to suction out my farm tank and install new filter and fuel. I offered to split the difference on the cost between what I paid for last week and what it cost to refill with fresh fuel this week. They agreed, so, I guess the problem is solved. Thanks for all the replies and help.
