L3130 IntelliPanel
   / L3130 IntelliPanel #1
PROOT
VA
KUBOTA L3130
Panel went blank 5 amp fuse is good
green turn signal lights come on but nothing elese.
I found the T1060-18660 SENSOR REVOLUTION broken off.Would that cause the panel to go blank.
PTO works but the seat safety does not and the glow plugs don't seem to be working.
I will have to un-bolt the sensor from the transmission ,anybody no how it is connected.
   / L3130 IntelliPanel #3
You have more then a broken sensor being the problem check all fuses, relays, battery and ground connections.
David Kb7uns
The fuse is good,the connector got pulled and broke off and probably shorted the wires together. I will check relays and grounds tomorrow. My gut feeling is that when the sensor wires shorted together it blew the board.
   / L3130 IntelliPanel #5
The glow plugs get power from fuse block by battery but they get control power from the Intellipanel. Check main fuses by battery and also fuse block by clutch pedal and find out what works and what does not and then I can look in service manual flowchart.
David Kb7uns
David ,all fuses are good. I checked all the connectors and all seem to be tight.
Is it possible that the power for the panel goes threw the REVOLUTION SENSOR and with it broken its not sending power to the panel.
lights ,turn,signal,parking brake warning light all work,no glow plugs,tach or digital display.
   / L3130 IntelliPanel #7
Sensor has three wires, ground, 12v, and signal that is around 2v. There are 2 connectors on panel, the 16 pin connector pin 1 is 12v and pin 11 is ground. If you have power there it may be Intellipanel, if no power the problem is in the harness.
David Kb7uns
   / L3130 IntelliPanel #9
The black and black/yellow stripe next to the red are grounds for sensor and circuit line, below the black/yellow stripe in the next row is another black and it is the main ground If you have power there and the display is not coming on then there is a problem with the panel.
In service manual it has in order.
Check battery
Check slow blow fuse (This is in box by battery at front of tractor)
Check connector to panel
And if nothing replace panel
Until you get something displaying on the panel none of the other tests can be done.
David Kb7uns
Thank you David Kb7uns for all your help. I do have power between the the red and the main ground.
Do you know of anything that can be done inside the panel or do I just need to replace it.
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
Mahindra 26XL Tractor 4X4 Loader Backhoe (A51243)
Mahindra 26XL...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
2021 Isuzu NRR (A50323)
2021 Isuzu NRR...
2007 Reitnouer 40 Ton T/A Flatbed Trailer (A49461)
2007 Reitnouer 40...
