L3130 IntelliPanel
   / L3130 IntelliPanel #11
If you had good electronics background I would say look inside but user replaceable parts probably not available. You could of popped a component or burnt a trace but it is hard to tell.
David Kb7uns
   / L3130 IntelliPanel #12
Well assuming it is already toast, it won't hurt to take it apart and have a look. Take lots of photos of connections and circuit boards - closeups with the macro mode on your camera - and then post them up. One of the electronics guys may be able to spot something. I'm sure the replacement will be quite pricey, so you lose nothing by at least taking a look at it.
   / L3130 IntelliPanel #13
If it was me I would be in it in a second but nowadays it is getting hard to find people doing component level repair or even that can solder. In my Ham radio hobby all the newbies coming up want premade wires and harnesses. For the panel to be totally dead it is a major problem that should be a trace or voltage regulator.
David Kb7uns
I did take it apart nothing looked looked burnt or popped I will take a second look.Now to figure out why,the only thing that I know of that happened is I tore out the revolution sensor connector.I am thinking it may have shorted the wires together.
   / L3130 IntelliPanel #15
Burnt electronics have a distinct smell. Check the board by smelling along with visual.
I don't know about the glow plugs, but the display might have lost the backlight?? I am guessing a simple LCD display with cathode tube backlight probably? They used to be on laptop displays and even if the LCD panel was good, it was dark when the backlight went out.
I don't know if this is your problem or even if it functions that way, but it might be..
2012 SULLIVAN PALATEK AIR COMPRESSOR (A51222)
2012 SULLIVAN...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
Landoll (A50657)
Landoll (A50657)
