L3130 HST 4WD question?
/ L3130 HST 4WD question? #1
penokee
Platinum Member
Little Girl's Point (Lake Superior), MI
Ferguson TO-20 (sold to son-in-law), AC - H3 Crawler, L3130HST, (AC-WD w/Attachments - SOLD), 1984 Honda Big Red, Honda Foreman 4x4 w/plow
Did the first 50 hour change on the Front Axle Case Oil, and could only get 4 qts. to go back in. Book says it holds 6.9 qts.
Parked on a level surface, removed both drain plugs, filler plug and overflow plug, let it drain for 1/2 hour (much grey in the oil which I assume is metal from the breakin period). Cracked both drain plugs while filling to bleed out any trapped air.
The shift was in 2 WD, could that have restricted the flow out?
Got me stumped.
penokee /forums/images/graemlins/smile.gif
/ L3130 HST 4WD question? #2
I had the same experience with my L3430, it seemed to just need about a gallon. Not sure what the deal is. I'm a little confused about that also.
jmc - good to know that I'm not the only one - hopefully someone will come up with the reason for it.
/ L3130 HST 4WD question? #4
I've read a lot of posts about the manual being wrong on the amount of fluids needed. I thought that seemed a little strange that the manual would be wrong. Maybe that's it though. I will be interested to see what the experts think.
Jim
/ L3130 HST 4WD question? #5
I had the same experience with my L 2800. No idea why.
/ L3130 HST 4WD question? #6
Yup the manual is wrong on many of the capacities. I just install the corrected capacities.
/ L3130 HST 4WD question? #7
Penokee,
I will be doing my 50-hr on my 3130 this weekend. After reading your post, I will note how much UDT I put in the front axle, and relay that to you. It sounds like the capacities in the manual might be off. I have not looked, but are there drain/fill plugs on the right and left side of the axle?
If there are two drain plugs on each side, what do you think about this approach to get as much fluid out of the front axle as possible?
1) Use the FEL to raise the front end off of the ground.
2) Pop plugs on one side of axle, drain.
3) Raise opposite side of front axle to let gravity help get as much fluid out as possible.
4) Repeat plug removal, drain process for other side
/ L3130 HST 4WD question? #9
Yes I did...was I supposed to say SUDT? /forums/images/graemlins/wink.gif
caylor - worth a try. I drained one side and when that slowed to a drip opened the other drain. Opened both the filler plug and the overflow plug to facilitate air flow/draining. Filler plug and overflow plug only on left side.
Would be a little handier if the drain plug faced inside rather then back, but suppose that's to give it some protection. I had some trouble with getting a funnel to handle the flow - drained some onto the blacktop /forums/images/graemlins/grin.gif
I used UDT when I replaced the fluid. Gears are turning pretty slowly, UDT should be fine in my judgement, but then I'm no Kubota expert.
Will look for your results. Could have it done at the dealer, but I feel changing fluids, etc. is part of the "Tractor Thing", and if you have time allows you to understand the workings of your machine a little better.
/ L3130 HST 4WD question? #11
Had the same problem with my L3430. Came out about two quarts short. The listed capacity must be wrong.
I am due for the 400 hour axle change soon. I will carefully drain and see what it will hold. I use Kubota 80w-90 Gear Oil.
ksmmoto
/ L3130 HST 4WD question? #12
I had the same thing happen to me. It only took about a gallon to fill the front axle on my L3130. I too, was wondering about this.
Curt
/ L3130 HST 4WD question? #13
My L3130HST had 90w gear oil in it.
Also have extra quarts of it like everyone else.
/ L3130 HST 4WD question? #14
Penokee
Just like you, I could only get around 4 qts of UDT in the front axle case. I put the tractor in 4wd, raised the front end, tilted the axle and drained each side for around 2 hrs each. Looks like the manual may be off, or we cannot get all 6 qts out using the drain plugs.
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2022 EZ-GO ELITE...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
New/Unused Wolverine 84in Snow Pusher (A65583)
New/Unused...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
