L3130 HST 3 point lift question
   / L3130 HST 3 point lift question #1
penokee
Platinum Member
Little Girl's Point (Lake Superior), MI
Ferguson TO-20 (sold to son-in-law), AC - H3 Crawler, L3130HST, (AC-WD w/Attachments - SOLD), 1984 Honda Big Red, Honda Foreman 4x4 w/plow
When I raise my Box Blade, it doesn't start to lift until the lever is around #5. Is this normal? Seems to me it would raise almost immediately before I monkeyed around trying to adjust the hydraulic speed with that control under the seat.
penokee /forums/images/graemlins/smile.gif
   / L3130 HST 3 point lift question #2
If I understand you correctly, then yes this is normal.
Your lever is numbered something like 1-9. 1 would be when the 3-point arms are on the ground and 9 being when the arms are at max height.
Now where the 3pt arms connect to your box blade would be at about #4 on your lever. So as you raise the box blade starting the lever at the #1 position it would not start to move until it got to about # 5 on the lever.
It would be just like your 3 pt arm not going all the way to the ground when your box blade is attached and your lever is at #1, the arms being connected to the box blade prevents them from droping down.
When I connect my bush hog to my L3130 it does not start to pick it up until I get to #6 or7 on my lever arm. Thats because I have lifted the arms up past what would be #5 on my lever in order to connet them to the hog.
Not sure I explained this real good, sometimes by the time my thoughts get to my fingers something happens to them /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/grin.gif
   / L3130 HST 3 point lift question #3
Mine does the same thing. For instance: my finish mower links are closer to the ground than my box blade links. So when I raise my finish mower, it starts to pick up around level 3. When I raise my box blade, it starts to pick up around level 5. Similarly when I lower the implements, my box blade is completely on the ground at level 5 and my finish mower is completely on the ground at level 3.
I don't think your monkeying around with the speed control had anything to do with it /forums/images/graemlins/smirk.gif.
Lawrence
Thanks to both of you. Had been doing some Bush-hoging then switched to the Box Blade, that's when I noticed it. Feel better now - thanks again.
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
Ranch Hand Pickup Truck Grill Guard (A49461)
Ranch Hand Pickup...
2001 INTERNATIONAL 4700 (INOPERABLE) (A50854)
2001 INTERNATIONAL...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
Unused 2025 CFG MX12RX Mini Excavator (A49461)
Unused 2025 CFG...
