L3130 HST 3 point lift question
   / L3130 HST 3 point lift question #1
penokee
Platinum Member
Little Girl's Point (Lake Superior), MI
Ferguson TO-20 (sold to son-in-law), AC - H3 Crawler, L3130HST, (AC-WD w/Attachments - SOLD), 1984 Honda Big Red, Honda Foreman 4x4 w/plow
When I raise my Box Blade, it doesn't start to lift until the lever is around #5. Is this normal? Seems to me it would raise almost immediately before I monkeyed around trying to adjust the hydraulic speed with that control under the seat.
penokee /forums/images/graemlins/smile.gif
   / L3130 HST 3 point lift question #2
If I understand you correctly, then yes this is normal.
Your lever is numbered something like 1-9. 1 would be when the 3-point arms are on the ground and 9 being when the arms are at max height.
Now where the 3pt arms connect to your box blade would be at about #4 on your lever. So as you raise the box blade starting the lever at the #1 position it would not start to move until it got to about # 5 on the lever.
It would be just like your 3 pt arm not going all the way to the ground when your box blade is attached and your lever is at #1, the arms being connected to the box blade prevents them from droping down.
When I connect my bush hog to my L3130 it does not start to pick it up until I get to #6 or7 on my lever arm. Thats because I have lifted the arms up past what would be #5 on my lever in order to connet them to the hog.
Not sure I explained this real good, sometimes by the time my thoughts get to my fingers something happens to them /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/grin.gif
   / L3130 HST 3 point lift question #3
Mine does the same thing. For instance: my finish mower links are closer to the ground than my box blade links. So when I raise my finish mower, it starts to pick up around level 3. When I raise my box blade, it starts to pick up around level 5. Similarly when I lower the implements, my box blade is completely on the ground at level 5 and my finish mower is completely on the ground at level 3.
I don't think your monkeying around with the speed control had anything to do with it /forums/images/graemlins/smirk.gif.
Lawrence
Thanks to both of you. Had been doing some Bush-hoging then switched to the Box Blade, that's when I noticed it. Feel better now - thanks again.
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52128)
2012 Freightliner...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
71064 (A49346)
71064 (A49346)
