L3130 dash lights
/ L3130 dash lights #1
MaxLee
Saratoga, New York
Kioti CS2410
Hello, Tractor ( L3130 GST) where my horse is boarded had the forward nuetral reverse lights go out on the dash. I am guessing that there is a switch under the dash that indicates the position the lever is in. Where would be a good place to look this part up.
TIA
MaxLee
/ L3130 dash lights
Depends. HST? 4WD?
I would start with “speed change shift fork”.
Its the GST... has the forward neutral reverse lever up on dash area... then it has like 12 forward and 8 reverse on left hand side of seat.
The lights on dash stopped workin to indicate what position the tranny is in
/ L3130 dash lights #8
Not telling you how to do stuff but have you checked the easy things like fuzes and power at the bulbs/light source?
/ L3130 dash lights
Not got that far into it. Figure there should be a switch to let the dash know what position the lever was in
PORTA POTTY (A68842)
BRADLEY MACHINE  MINI VAC TRAILER (A67714)
BRADLEY MACHINE...
PORTA POTTY (A67714)
2026 SG45 Hydraulic Stump Grinder Skid Steer Attachment (A66734)
2026 SG45...
THERM DYNAMICS TD 375 FLAMELESS HEATER (INOPERABLE) (A68842)
THERM DYNAMICS TD...
2012 CTS BELLY DUMP (A67714)
2012 CTS BELLY...
