L3130 dash lights
/ L3130 dash lights #1
MaxLee
Saratoga, New York
Kioti CS2410
Hello, Tractor ( L3130 GST) where my horse is boarded had the forward nuetral reverse lights go out on the dash. I am guessing that there is a switch under the dash that indicates the position the lever is in. Where would be a good place to look this part up.
TIA
MaxLee
/ L3130 dash lights
Depends. HST? 4WD?
I would start with “speed change shift fork”.
Its the GST... has the forward neutral reverse lever up on dash area... then it has like 12 forward and 8 reverse on left hand side of seat.
The lights on dash stopped workin to indicate what position the tranny is in
/ L3130 dash lights #8
Not telling you how to do stuff but have you checked the easy things like fuzes and power at the bulbs/light source?
/ L3130 dash lights
Not got that far into it. Figure there should be a switch to let the dash know what position the lever was in
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
2002 Sterling L7500 Series VacCon V390LHA Combination Sewer Jetter Vacuum Truck (A64556)
2002 Sterling...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2004 John Deere 8320 (A63688)
2004 John Deere...
KMC 14' FIELD CULTIVATOR (A64278)
KMC 14' FIELD...
2013 Ford Flex SUV (A64557)
2013 Ford Flex SUV...
