L3010 won" start
   / L3010 won" start #1
Larrythetarheel
Henderson
Kubota
My Kubota L3010 which has been great up until now, just begin to have a starting problem. The battery is good testing at 12.6 volts. When I turn the switch I would get one click then dash light would go out. Now turn the key and get no dash lights and no click from the starter.
   / L3010 won" start #2
Try jump starting it , even though the battery tests 12.6 amps it may still be bad or need charging . It is worth a try before going other routes .
   / L3010 won" start
Took the battery out and had tested, thanks though.
   / L3010 won" start #4
How are you making out ? I was hoping someone with more knowledge than myself would have chimed in by now. It could be a solonoid , dead spot on starter . I have seen people tap the starter to try and get it to work , not sure how good that works .
   / L3010 won" start #5
I'm assuming that you cleaned the cables when you took out the battery to test it but make sure they are clean and tight on the other end as well. A bad ground could cause this.
Sent from my iPad using TractorByNet
2016 Ford F-550 4x4 Ext. Cab Service Truck (A55788)
2016 Ford F-550...
DITCH WITH 3700 trencher (A55787)
DITCH WITH 3700...
2008 Isuzu NPR-HD Landscape Dump Truck (A55788)
2008 Isuzu NPR-HD...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55301)
2017 KINZE...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A55851)
2010 Turfco...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
