L3010 PTO Chipper
   / L3010 PTO Chipper #1
moot
Georgia
Kubota L3010
   / L3010 PTO Chipper
Thanks. I was only planning on running 6" max. through the 8" chipper.
Do you happen to know the hp @ the pto of the L3010?
Can you recommend a chipper that will work well with the L3010?
   / L3010 PTO Chipper #4
If you clicked on my Tractor Data link in the post above it has the info.
I will repeat it here -
Tractor power:
Engine:30 hp [22.4 kW]
PTO (rated):25.5 hp [19.0 kW]
With only 25 at the PTO I think 6 inch material would probably stall the tractor. If the chipper has a controlled automatic feed you may be ok as that should enable you to stop the feed when the tractor RPM's come down.
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
2008 Ford F-350 Altec Service Truck (A50323)
2008 Ford F-350...
377671 (A51573)
377671 (A51573)
14" Pipe Ditch Lift Pump (A50121)
14" Pipe Ditch...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
