L3010 HST Whine
/ L3010 HST Whine #1
kevincook
Platinum Member
k
Hello everyone,
I have 30 hours on my L3010 HST and the other day it started whining. The sound is coming from right underneath the floorboard so I am assuming that it is the HST. It is most noticable at 1500-1800rpm. Slower than that there is no sound and faster than that the engine noise is too load for me to hear any whining. When I push in the clutch the sound goes away. It doesn't whine all the time but it has now happened a couple times. What is the likely cause? Is it a problem? Should I not use the tractor until the dealer looks at it or should I just have them look at it at the 50 hour service which will probably be sometime in May?
Thanks for your help.
Kevin
/ L3010 HST Whine #2
Kevin,
Hydros whine. Is it an extreme noise as compared to what it was, or maybee something you just have'nt noticed before? If you're not sure have the dealer take a look at it.
/ L3010 HST Whine
I talked to the mechanic today and he said to just keep an eye on it for now and give him a call if I notice any drop in hydraulic power. I'm sure it is a new sound...it is very faint but it is there. I'll let you know how I make out.
/ L3010 HST Whine #4
Give him a call if you notice a drop in hydraulic power? By then the problem should be easy to find.
/ L3010 HST Whine #5
Kubmech,
Will using synthetic Tractor Hydraulic fluid (amsoil and the rest) make a hydro less noisy? This is not ment to start up the Dino Vs Techno oil debate. I am nearing my 50 hour service and I want to know if I can get quiter HST operation.
Thanks!
John Bud
/ L3010 HST Whine #6
John,
I personally have limited experience with synthetic oils, I have always used what the factory recommends, even in my personal stuff and never had a problem. I believe in the "if it aint broke........................" Most of what I know about the synthetics I get from other peoples' experience or opinions. Seems most have good luck using synthetics. As far as quieting the hydro I can't imagine it would be very noticeable if at all, that fluid still has to squeeze past those small clearances which can't help but make noise. But hey, ya never know.......
/ L3010 HST Whine #7
John,
Depends on outside ambient temperature...
Less than 40 degrees{winter time?}... absolutely./w3tcompact/icons/smile.gif
Above 40 degrees... hardly noticeable. /w3tcompact/icons/frown.gif
/ L3010 HST Whine #8
John, Thanks for the update. Since it is below 40 here in Wisconsin for about 15 months a year, I probably will go with a synthetic fluid. Actually, today was nice for a change. Started out in the 30's and ended up in the 60's.
No "whine" but a lot noise from using the FEL and the box blade to dig out a duck pond.
The only time I have ever objected to the HST noise was traveling on the road with the tractor in high range.
John Bud
/ L3010 HST Whine #9
My 3010 HST makes a whirlling sound in the back end when driving fast down the road. It has done so since
Hour 1. I have no loss in power but it does lug heavily when trying to start up in High range on the HST.
I have FEL and filled tires so the extra weight might cause the lugging of the engine in High.
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
2001 Club Car Carryall 6 Medical Utility Cart (A64553)
2001 Club Car...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
Hardi Navigator Pull-Type Sprayer (A66285)
Hardi Navigator...
New/Unused 20 Ton Hydraulic Jack (A65583)
New/Unused 20 Ton...
