L3000LT throttle sticks
   / L3000LT throttle sticks #1
nealfris
Bronze Member
Marshfield, MA / Arlington, VT
Kubota '2003' L3000DT 8/4 std, engine/pto hp 32.1/27.5, hyd 6.9 gal/min
Hi all, need help with my sticking throttle on my Kubota. My standard gear tractor has dash and foot throttle. when shutting off the tractor the dash throttle arm moves freely but the foot pedal remains at rpm. I've lubed and checked linkage all the way to the engine.
I know engines and mechanical, but I don't know diesels. The previous owner checked in with dealer service dept. They told him it was inside the engine and expensive to fix. :mad:
I have loosened and removed the arm between linkage and vertical shaft going into engine. The shaft is definitely hanging up. Any advice on how to service and free up this shaft??? I've been dowsing it with PB blaster hoping it will run down inside. No luck! :confused:
Wow, no Kubota guru's out there???
   / L3000LT throttle sticks #3
Have you confirmed that it is sticking right at the pump? If so then it is an internal pump problem. Past that I can't help. Expensive:confused: probably:(
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
John Deere 5100M (A53317)
John Deere 5100M...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
Forklift (A59228)
Forklift (A59228)
