L3000LT throttle sticks
/ L3000LT throttle sticks #1
nealfris
Marshfield, MA / Arlington, VT
Kubota '2003' L3000DT 8/4 std, engine/pto hp 32.1/27.5, hyd 6.9 gal/min
Hi all, need help with my sticking throttle on my Kubota. My standard gear tractor has dash and foot throttle. when shutting off the tractor the dash throttle arm moves freely but the foot pedal remains at rpm. I've lubed and checked linkage all the way to the engine.
I know engines and mechanical, but I don't know diesels. The previous owner checked in with dealer service dept. They told him it was inside the engine and expensive to fix. :mad:
I have loosened and removed the arm between linkage and vertical shaft going into engine. The shaft is definitely hanging up. Any advice on how to service and free up this shaft??? I've been dowsing it with PB blaster hoping it will run down inside. No luck! :confused:
/ L3000LT throttle sticks #3
Have you confirmed that it is sticking right at the pump? If so then it is an internal pump problem. Past that I can't help. Expensive:confused: probably:(
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
2010 BMW 128i Convertible Coupe. (A61574)
2010 BMW 128i...
Geringhoff Control and Manuals (A63117)
Geringhoff Control...
2021 TAKEUCHI TB240 EXCAVATOR (A64279)
2021 TAKEUCHI...
2025 Kivel 48in Fork and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
