L3000DT tail light
/ L3000DT tail light #1
cp1969
Kansas
Kubota L3000DT
There is a light on the left fender of my tractor which is on (brightly) all the time. It is a separate light from the flashers. Is this supposed to be this way? I find no mention of it in the manual.
/ L3000DT tail light #2
My L2600DT is the same way. I initially thought that it was a brake light, but like yours, is on all the time. Just a bright tail light I guess.
/ L3000DT tail light #3
Try this, There are two wires going to the tailight, Disconnect one (I forget which color) It's the one that's hot when the key is on. Then leave the one that's hot only when the lights are on.
Kubmech
Thanks. I will try disconnecting one wire. I don't see any reason to have it on all the time.
/ L3000DT tail light #5
I have an L3000DT also and that light is always on when the key is turned to the run position. I thought it was a warning light to let people behind you know that the tractor was running.
I don't see a problem with the light. If you don't want it on take the bulb out of the socket.
Randy
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
1989 STE 307 SS 4 Comp Non Insulated T/A Chemical Tanker Trailer (A64194)
1989 STE 307 SS 4...
2012 Jeep Compass SUV (A64194)
2012 Jeep Compass...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2008 FORD E- 350 S/A MOBILE PET GROOMING VAN (A67148)
2008 FORD E- 350...
KMC 3PT W/ 3 X 3 TOOL BAR (A64278)
KMC 3PT W/ 3 X 3...
