L3000DT tail light
/ L3000DT tail light #1
cp1969
Kansas
Kubota L3000DT
There is a light on the left fender of my tractor which is on (brightly) all the time. It is a separate light from the flashers. Is this supposed to be this way? I find no mention of it in the manual.
/ L3000DT tail light #2
My L2600DT is the same way. I initially thought that it was a brake light, but like yours, is on all the time. Just a bright tail light I guess.
/ L3000DT tail light #3
Try this, There are two wires going to the tailight, Disconnect one (I forget which color) It's the one that's hot when the key is on. Then leave the one that's hot only when the lights are on.
Kubmech
Thanks. I will try disconnecting one wire. I don't see any reason to have it on all the time.
/ L3000DT tail light #5
I have an L3000DT also and that light is always on when the key is turned to the run position. I thought it was a warning light to let people behind you know that the tractor was running.
I don't see a problem with the light. If you don't want it on take the bulb out of the socket.
Randy
2026 Electric Tricycle (A64194)
2026 Electric...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2022 EZ-GO ELITE...
(APPROX. 450')LOT OF LATCH LOCK 6" IRRIGATION PIPE (A64278)
(APPROX. 450')LOT...
TAKEUCHI TB240 EXCAVATOR (A65053)
TAKEUCHI TB240...
YALE FORKLIFT (A63291)
