L3000 won't start
   / L3000 won't start #1
DBLA
Florida
Kubota L3000
No lights on dash, won't preheat glow plugs, battery checks good (12.6v), short across solenoid does nothing
Ignition switch?
   / L3000 won't start #2
Safety switch. I did the same thing when I bumped the pto lever getting out of the cab and nothing would happen.
   / L3000 won't start
Found that battery was shorting out when key was turned on. Cleaned terminals and connectors, fired up!
   / L3000 won't start #4
All electrical troubleshooting should start at the battery, voltage at the posts is not a valid indicator. Voltage at the cable ends under load is much better. Tractors don't typically get "fuzzy" corrosion like cars do, they get a black corrosion that you can't see until you take the cables off and clean the terminals and posts. I never start any electrical troubleshooting without doing this first and testing the battery.
Brian
   / L3000 won't start #5
I have a much different tractor (a G1800) but I experienced similar symptoms last month. In my case, the lights would light up but the starter wouldn't engage. I won't go into everything I tried, but the problem turned out to be a bad battery ground cable connection. Try removing the cable from the chassis and lightly grinding down or cleaning the metal on the chassis and the cable connector. Even if that's not the problem, it's not a lot of work and costs nothing to do. If it doesn't work you will have at least eliminated one source of the problem.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A51039)
2019 New Holland...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2000 KOMATSU VALMET 860.4 FORWARDER (A51222)
2000 KOMATSU...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
