L2900
   / L2900 #1
sonny
Lillian,Texas 76061
M9000-L2900(kubotas)
My L2900 only has 400 hrs,and I think a bearilng in the rear axle maybe out.
It makes a popping noise like the wheel is loose.Any suggestions would be appricated.
thanks
   / L2900 #2
If the wheel in question has a center disc bolted to the axle flange with the outer rim bolted to the disc, check the outer bolts. If they work loose at all, it will make a popping sound as it shifts around, and sound a lot like a dry bearing. It's far more likely than an axle bearing failure with only 400 hrs
   / L2900
thanks for the reply,i will try that
i posted again,didnt know where the listing was?
thanks
   / L2900 #4
I have the same problem by my L2900 gst has 846 hours. I will check the wheel lug nuts first thing tomorrow. I noticed it while picking up my hay....I place it in 2nd and let it go while I load the bails on the trailer. I placed my hand on the wheel as and it popped at a specific spot.
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
2022 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2022 JCB HM180T...
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
2015 FREIGHTLINER CASCADIA DAYCAB (A50854)
2015 FREIGHTLINER...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A51039)
2007 Freightliner...
