L2800HST owners question
   / L2800HST owners question #1
solo169
Manassas, VA
2006 Kubota L2800
I just took delivery of my L2800HST after debating for weeks between it and the L3400HST. The dealer is willing to let me trade up if I feel I need the extra HP but he was convinced the L2800 would be plenty as I have a fairly flat 10 acres. I would rather save the $1000 extra $$$$ also. My Question is, can I mow in medium or high gear with a Woods RD72 finish mower? I don't have any tall grass right now due to the time of year --- winter. I don't expect to be able to mow in high gear but at the same time I really don't want to crawl around in low either. Any others out there use their L2800HST for finish mowing? If so, what mower do you use and what gear do you generally use. Any problems? Thanks!
   / L2800HST owners question #2
Cant answer your question about finish mowing.....BUT I use a 5' bush hog in Meduim range on my L2800 HST.
With the Hydro Trans I can adjust the speed of travel quickly with the foot pedal. Low range is very slow for cutting in an open field unless it's rough, HIgh range is way to fast for anything but getting there /forums/images/graemlins/grin.gif
   / L2800HST owners question #3
I can't comment on the L-2800 but I can tell you that I always finish mow in High with my B-7500, I mow with a Woods RD 6000.
I would suspect that you will be able to mow in high at very least medium.
   / L2800HST owners question #4
I finish mow in high, with a 72" Befco, using my L3400 HST on a regular basis. Does not strain the machine at all.
I suspect you will have no issue.
Good Luck
   / L2800HST owners question #5
I used a 60" finish mower in med spd (L2800HST) last summer with no problems. Medium speed was fast enough for me due to terrain.
   / L2800HST owners question #6
In general, use as low of range as possible. If you can't mow fast enough using full pedal in medium then switching to high is not a problem. If the grass is too long or wet you'll hear the engine or mower belt complaining and then you should slow down.
On most of my property mowing speed is limitd by the bouncing. You don't want your equipment banging around.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
Grundfos Centrifugal Pump (A50121)
Grundfos...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
