L2800 HST running backward
/ L2800 HST running backward #1
Boatman62
Mill Spring, NC
Farmall H, JD 4110, Kubota L2800, Kubota BX1870
Had an interesting thing happen today... I was pulling stumps and one of them stalled the engine for a second but the engine restarted itself. Sounded kind of strange. Sat there a few seconds and thought it might clear itself... it didn't. I tried to back up and when I pressed reverse the tractor went forward, pressed the forward pedal and the tractor went backward. I thought I was imagining it so I tried again and same same results. I tried to raise the fel but it just fell to the ground.... no hydraulic pressure at all. Then I realised the engine was running backward so I shut it down. Waited a few seconds and restarted it and everything was back to normal. Used the tractor for another hour without incident.
Over the years Ive had engines run backward a couple times... mostly 2 strokes. But never with anything hydraulic related. Could this have done any damage to any of the pumps?
/ L2800 HST running backward #2
This happens to me once in a while when I pull logs with my pto skidding winch. Shut it down immediately! I doubt the oil pump works in reverse rotation. Luckily for me, my father was right there when it happened the first time and he knew what was going on. Now I recognize it immediately and shut it down.
/ L2800 HST running backward #3
Given the short duration, and everything submerged in oil, you are probably fine.
Probably ran a maximum of 45 seconds. More concerned with the hydraulics than the engine itself.
/ L2800 HST running backward #5
Doubt there was any damage to the hydraulics. If allowed to run that way the HST would eventually revert to neutral because the charge pump wouldn't be keeping the main pump/motor circuit full of oil. But no damage would be done.
/ L2800 HST running backward #6
Thanks for posting, I'll keep that in mind... I've stalled it once... but that was it.
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2011 Chevrolet Impala Sedan (A59231)
2011 Chevrolet...
LIGHT TOWER (A56857)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
2025 JMR Tree Boom Mini Skid Steer Attachment (A59228)
2025 JMR Tree Boom...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
