L2800 clutch adjustment?
   / L2800 clutch adjustment? #1
clovergamecock
Clover SC
Kubota L2800 4WD FEL
In 1st gear low I have no problems with hills but if I move into the higher gears and try to go up even small incline it comes to a stop. PT works fine, bucket and 3 pt work fine, 4wd works fine.
Worn out clutch or is there an adjustment? This is a 2004 model.
   / L2800 clutch adjustment? #2
When it comes to a stop are you implying the engine continues to rev? If so, it sounds like the clutch is slipping, but I would expect that you should smell the clutch burning. If no smell perhaps the clutch is oil contaminated due to a bad rear main seal.
Looking at the parts diagram (see attachment, part highlighted) there is an adjustment but can't give you specifics on how it should be adjusted. With any luck that is all it is.
Did you check the clutch housing plug with the small pin in it? Push up on the pin and see if any fluids come out.
Good luck
   / L2800 clutch adjustment? #3
you can adjust the clutch be if its that bad you may have waited to long
Hi, thanks for the replies.
The tractor does not turn off when going up an incline it just comes to a stop or a very slow crawl. I have to put it in 1st low in order to climb the incline. If I am on a flat surface I can drive using all gears. There does appear to be more play in the pedal than the 3/4" I have read about. I did not get a chance to adjust it yesterday.
I don't smell clutch burn. I have smelled it in the past when moving heavy dirt and changing from 1 gear to another.
"If" I end up replacing the clutch what kinda of cost am I looking at? I have plenty of experience replacing clutches in cars but not sure I have the equipment needed to separate the front from the rear.
Thanks
WW
   / L2800 clutch adjustment? #5
Did you ever get this diagnosed and repaired? I am having the same issues.
Thanks
   / L2800 clutch adjustment? #7
Good question, sorry.... This is a L2650, (profile edited)
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
1999 Ford Ranger Pickup Truck, VIN # 1FTZR15X6XTA79787 (A51572)
1999 Ford Ranger...
2018 COLOMBO TM LOT NUMBER 184 (A53084)
2018 COLOMBO TM...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2021 JOHN DEERE 8R340 LOT NUMBER 209 (A53084)
2021 JOHN DEERE...
