Goreef
- Joined
- Aug 26, 2016
- Messages
- 34
- Location
- Smithville Texas
- Tractor
- mahindra 6530 4x4 2013 .Bought at J5. Great dealer,i would highly recommend
Wondering what i should expect to pay for a L2501 gear drive 4 wheel drive with loader.
I had a L3200hst same machine pre-emissions tweaks only with a HST. Make sure you get the rear tires loaded for traction & stability while using the loader. If you ever plan on using anything but the bucket get the SSQA loader, it's so worth it.Thanks for the info. Can you tell me how you are liking your tractor and is there anything you dont like.
I can tell you why I went HST, but gear does have a few advantages.I'm curious why you would choose the gear drive shuttle shift over the HST?
rScotty
Every dealer I've talked to is confused about HST repair just because it comes up so rarely. Your clutch is much more likely to have issues & it's a designed wear part. Anything, including a clutch job requires splitting the tractor, which is kind of complex & expensive.I just worry about problems down the road and the fix being expensiveand i also dont know anything about them. Gear drive just seems like there is less to go wrong.
.... Personally I'll never go back to a HST.....
