L2500DT won't roll over
   / L2500DT won't roll over #1
carlav1410
Bronze Member
Mt Airy NC
Kubota L2500DT 4X4
Hello all,
I have a 2000 L2500DT that won't roll over?
I have good lights,glow plugs heat up all safety switches are by pasted.
I have good voltage at starter.
Wondering if it could be the key switch causing my trouble?
Thanks to all
   / L2500DT won't roll over #2
I was going to ask how big a hill you were trying to roll it over on. :laughing:
Is there any sound from the starter? Clicks or groans?
You are sure the seat or clutch safety switches are not causing the issue? If everything is by-passed and there is no sound at all from the starter, perhaps it has gone out?
   / L2500DT won't roll over #3
Hello all,
Thanks to all
If you can hot wire it successfully, then it's time for a new switch. Or you could do a quick continuity test to confirm your suspicion.
Thanks for all your replies I'm going to test out the starter today.
I'm also going to check the key switch out to see if there is any voltage when the key is in the start position?
Thanks Again Carl
Back again,
I tested the starter and key switch have 12 volts at key switch went turned to start.
If i jump starter from large to small terminal tractor rolls over.
I'm thinking problem might be in wiring harness ?
Anyone have ideas?
Thanks Carl
   / L2500DT won't roll over #6
Most likely a failed safety switch. Bypass one at a time until you have joy.
Mike
Thanks to all,
I found the trouble.:D It was the arm on the neutral safety switch not pushing the pin on switch far enough in to make connection.....:confused2::confused: only wasted 4 hrs on it.:mad:
Again Thanks to ALL for the awesome advice Carl
   / L2500DT won't roll over #8
My transfer case lever , must be wiggled sometimes to make it crank> Just a Tip?
   / L2500DT won't roll over #9
After adjusting free clutch travel on my L225DT, I had the same problem. Had to glue a metal block on the clutch rod to complete circuit. Took me a while to figure that out.
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
