L245DT
/ L245DT #1
twodogs
Pittsburgh, PA
Kubota B7800
I am considering the purchase of an L245DT. It is being sold with a 5' finish mower & a plow. I am new to this, please forgive my ignorance.
I am considering selling my Ford 8N so that I can purchase this Kubota. I have a 5' brush hog for the Ford, I would like to keep it for the Kubota, if it would work on it.
I would like to cut my yard (about 3 acres), and my fields (about 20 acres - once per year). I would also like to be able to plow my paved driveway (Pittsburgh area). Does anyone know if this particular tractor has the ability to do all of those things? Ideally, I would like to have a MMM for the yard. Is this tractor capable of handling that? The tractor is rated at 22hp - would it handle a 5' brush hog for my fields?
Any input would be appreciated. Thanks!!
/ L245DT #2
Hey twodogs, I had one of those before I bought my 3010. It would probably handle a 5' hog if you have flat ground. If your only going to bush hog your field once a year it would probably be slow going. I had 4' on my 8N, but it was because of my hilly land and the 8N's gearing. I had real good experience with mine, it was a great little tractor. You will be impressed, theres a big difference between that little tractor and the 8N. Mine would go places I'd never dream of taking that 8N through. I would think you could purchase a mid mount mower if it has a mid mount pto, not sure though.
Good Luck.
Steve
/ L245DT #3
I bought a L245DT in 1981 and traded up in 2000 for a 3710. I too had a dozer blade on the front and a 5' finishing mower, and used a 5' bushhog. I cleared 15 acres of heavy brush and small trees with the L245DT, as well as plowed snow for years on a long driveway. I also used an auger to drill holes for fence posts and cut a lot of grass with the finishing mower. The only reason I traded up was that I wanted a frontend loader and the 245 did not have power steering. I had ag tires on it, and it was incredible the places it would go! They don't build them like that one anymore. I kept it waxed and in a garage and it looked as good as new the day I sold it! Good luck, you won't regret it!
/ L245DT #4
TwoDogs..I have an L235..it might be old, but it does me just fine..I have a 5' Howze brush hog, FEL and a 5' box blade with the tractor..I routinely cut 5 to 7 acres of hay several times a year plus use the FEL for all kinds of stuff..all I can say about buying your L245 is. check it out real good..that it's mechanically sound..how many hours does it have..maintenance history..etc..
/ L245DT #5
I bought a L245DT in OCT. 2004, It had abt 1200 hrs on it, has a Bush Hog brand FEL, 5 ft bushog, boxblade, and I just bought a post hole digger, not sure what year model mine is, but it is a workhorse, have not found anything it can't handle, within reason...good luck
Panorama Hayrake (A66408)
Panorama Hayrake...
Skid Steer Roto Tiller (A65640)
Skid Steer Roto...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
Invoices (A65640)
Invoices (A65640)
2022 SANY SY35U EXCAVATOR (A63276)
2022 SANY SY35U...
