L245DT Hydraulic/Transmission Fluid
   / L245DT Hydraulic/Transmission Fluid #11
I have an old 1976 Kuboto L245DT tractor with a front loader & a 3pt. lift in the rear. The front loader is acting sluggish, any ideas ? I have checked the fluid levels.
   / L245DT Hydraulic/Transmission Fluid #12
There is a screen filter located on the left side of the trans. Clean this and problem will likely go away. My three point lift arms were slow in the winter and this was the problem.
   / L245DT Hydraulic/Transmission Fluid #13
I am using TSC hyd/trans oil. No problems the last 30 years. Parts manager at Kubota says it is only good for starting fires.
Wooden Handle Double Headed Axe (A57454)
Wooden Handle...
Heaven Hill Bourbon Barrel (A57454)
Heaven Hill...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
