L245 DT, Anyone else?
/ L245 DT, Anyone else? #1
rodsauder
ON
Mitsubishi Kubota
Being new to tractors, hobby farming etc, I have a question. I purchased a Kubota L245DT with front end loader, this tractor has sat in a barn for approx 20 years. I changed all the fluids and have really enjoyed the first couple of hours playing with it. I find the bucket and boom ( hope that is what its called) controls very slow. So my question is ,Did I miss a filter or screen somewhere for the hydraulics? I do not see anything outside (visible) does anyone have a similar tractor and can make suggestions. BTW, tractor has 1300 hours on it ( according to guage ) I tend to believe it looking at the overall condition of tractor. Regardless of hours, I now own it and will do what it needs to keep it in good shape. So any input ,comments or questions are welcome. Thanks in advance.
/ L245 DT, Anyone else? #3
The L245 internal hydraulics are not speedy but should not be really slow either. There is a strainer INSIDE the transmission where the pump's feed pipe connects (low on the side). Any auxiliary hydraulics on this tractor? If so, post some pics showing how they are connected - sometimes flow gets divided or blocked if hoses get swapped.
/ L245 DT, Anyone else? #4
What RPM is the engine running when you use the loader or boom? My hydraulics are very slow at low engine RPMs as the pump can't move much volume/time at that speed. It gets VERY responsive at high RPM.
Thanks Daver1963, I found the service manual and it seems as if my tractor is a 1976 model year. Perfect. That sure was easy. I will check check for that strainer/screen inside the transmission also. I never revved up the engine very much when using the bucket, I will check the rpms and see if the response changes with the increased rpm. Thanks to everyone that took the time to answer me. Once I have the bucket rebuilt I will try and post some pics. (Bucket was basically bent on the bottom and cutting edge was broke. Thanks again.
/ L245 DT, Anyone else? #6
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2020 Kenworth T680 Sleeper (A62613)
2020 Kenworth T680...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
Frontier Hay Spear (A64126)
Frontier Hay Spear...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
