L2350. need to grease the clutch release ??
   / L2350. need to grease the clutch release ?? #1
Gamemaster
Erie,Pa.
Kubota L2350DT
L2350 gear-trans....Whoops. I thought I did all the maint. ,but missed one. The manual states there is a grease fitting on the clutch release ?. There is a steel cover on the right side of the trans/clutch hsg. Remove it and grease the fitting. Huh!. I removed it but don't see any fitting. The access hole is about 4"x4" square. I see a shaft-looking device inside,about 6" deep but don't see any grease fitting. It is coated in a fine dust. Is it a recessed fitting that needs needle tip .Do I need rotate the shaft? If so, how?..Need some help here.
   / L2350. need to grease the clutch release ?? #2
Only the older L2350's had the grease fitting my'en is a 96 and it doesn't have one either and the manual state it does. Never changed the manual i guess.
John Deere 7810 Tractor W/Loader (RIDE AND DRIVE) (A50774)
John Deere 7810...
2004 Chevy Utility Van (A47384)
2004 Chevy Utility...
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
PALLET OF TRAMPOLINES & TRAMPOLINE PARTS (A51244)
PALLET OF...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
Massey Ferguson RB 4180V Round Baler (A50774)
Massey Ferguson RB...
