L2350. need to grease the clutch release ??
   / L2350. need to grease the clutch release ?? #1
Gamemaster
Erie,Pa.
Kubota L2350DT
L2350 gear-trans....Whoops. I thought I did all the maint. ,but missed one. The manual states there is a grease fitting on the clutch release ?. There is a steel cover on the right side of the trans/clutch hsg. Remove it and grease the fitting. Huh!. I removed it but don't see any fitting. The access hole is about 4"x4" square. I see a shaft-looking device inside,about 6" deep but don't see any grease fitting. It is coated in a fine dust. Is it a recessed fitting that needs needle tip .Do I need rotate the shaft? If so, how?..Need some help here.
   / L2350. need to grease the clutch release ?? #2
Only the older L2350's had the grease fitting my'en is a 96 and it doesn't have one either and the manual state it does. Never changed the manual i guess.
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
Unused 2025 CFG Industrial QNT50R Mini Excavator (A50322)
Unused 2025 CFG...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
2013 Ford F-550 4x4 Altec Bucket Truck (A50323)
2013 Ford F-550...
