L2350. need to grease the clutch release ??
   / L2350. need to grease the clutch release ?? #1
Gamemaster
Erie,Pa.
Kubota L2350DT
L2350 gear-trans....Whoops. I thought I did all the maint. ,but missed one. The manual states there is a grease fitting on the clutch release ?. There is a steel cover on the right side of the trans/clutch hsg. Remove it and grease the fitting. Huh!. I removed it but don't see any fitting. The access hole is about 4"x4" square. I see a shaft-looking device inside,about 6" deep but don't see any grease fitting. It is coated in a fine dust. Is it a recessed fitting that needs needle tip .Do I need rotate the shaft? If so, how?..Need some help here.
   / L2350. need to grease the clutch release ?? #2
Only the older L2350's had the grease fitting my'en is a 96 and it doesn't have one either and the manual state it does. Never changed the manual i guess.
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Bale Ring (A50515)
Bale Ring (A50515)
2021 HYUN Elantra (A50324)
2021 HYUN Elantra...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2014 Honda Accord (A50324)
2014 Honda Accord...
