L2250 transmission oil drip
   / L2250 transmission oil drip #1
capt023
madison TN
john deere 4400
L2250 dripping oil from hex head with a small plunger
l2250 dripping oil under tranny - what is this ????- it just started dripping
   / L2250 transmission oil drip #2
Is it loose? Bad gasket?
willy
   / L2250 transmission oil drip #3
That bolt and pin flopping around is just doing what it's suppose to do. The pin just keeps the drip hole clear of obstruction, while the drip hole lets moisture and oil come out of the bellhousing.
The fact that you have oil running out of it, means that you have either a bad rear main seal, a bad transmission input shaft seal or a 4WD output shaft seal leak. However, look at the color of the fluid, I would say it's the transmission input shaft or the 4WD output shaft if you have the 4WD model. If it was the rear main seal, the oil would be darker.
   / L2250 transmission oil drip #4
Post 3 nailed it. Bad seal. If not too bad, ignore it. It entails a split no matter what. My M9 open station with 6 K hours weeps a bit too. I ignore it.
   / L2250 transmission oil drip #5
Like others said it appears you have a transmission seal leaking by the oil color.
I cant tell what kind of trans its has. Manual, GST or Hydro.
Its not anything to do with the 4wd as the drop box on this model is further back on the trans.
And yes to fix it will require the tractor be split.
I think I’ll ignore it if it doesn’t get a lot worse - thanks
Thanks
Thanks
Thanks
   / L2250 transmission oil drip #10
You could use one of these to see exactly what is leaking and to make sure you are not getting any oil on your clutch disc.
They are fairly inexpensive and sync to your phone for viewing. There is a built in light that has adjustable intensity.
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2018 John Deere 470G LC Hydraulic Excavator (A55787)
2018 John Deere...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A55787)
2019 John Deere...
