L225 Trans problem
/ L225 Trans problem #1
greasy_fingers
I have a Kubota L225 that will not move when in 1st-2nd or 3rd-4th gear selection. Works in reverse and upper two gears. No sounds when I let out Clutch in 1st-2nd other than driveshaft noise as if in neutral, which it is I quess. Has anyone had any experience on a L225 Trans? Also what about value, horsepower, and yr of this tractor as I may sell when I get it fixed? It is a 2 wheel drive with turf tires. Overall Condition "fair to better" some sheetmetal damage and rust, etc. Where is a good place to buy used parts for this tractor??
/ L225 Trans problem #2
I'm not too sure if you have the symptoms straight?
If 1+2 are not working in hi and lo range (effectively 5+6)
then that sounds like a broken shift fork in the gear selector. If 1,2,3+4 work in low range but not in hi range (effectively 5,6,7+8) or viceversa then it's a broken range shifter fork. Usually if range fork is broke it will either be in low or hi with no range neutral.
Kumech: You are correct in that the 1-2 (effective 5-6)gear selection will not move tractor in either the Lo or Hi range selection. If this in fact means that I have a shift fork out of the gear selector, what must be done to repair, (must the tractor be split and the trans removed or can this be repaired by removing the shift tower?), and what will the parts cost (approx)?? How big a problem is this really. I alway do my own mechanic work, but I've never had a Japanese tractor apart, only 50 yr old Ferguson and International(farmall's and diesel crawlers). I appreciate you help in this matter! Greasy Fingers
/ L225 Trans problem #4
O.K. If I remember right, the shifter cover will come off exposing the trans gears and I think you can change the fork without splitting the machine. Give that a shot I'll have to check the manual tomorrow(if I remember)But I'm pretty sure it's not that big of a job. Parts should be minimal cost and still available.
/ L225 Trans problem #6
Greasy you're in luck this model has the shift forks attached to the shift cover This job is a piece of cake compared to the models that have to be split and trans case completely disassembled let me know how it goes.........
Thanks: Kubmech
It will be a few days before I can check this out, Busy season you know! I'll let you know when I find out what the problem is when I get in there.
Again, thanks for the info and help: Greasy Fingers
Single Cedar Glider (A65583)
Single Cedar...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2020 Polaris Ranger XP 1000 UTV (A65579)
2020 Polaris...
2012 Ford E-450 Sewer Viewer Van (A64556)
2012 Ford E-450...
AGRIC AFMJ65 - 65" ROTARY TILLER (A64277)
AGRIC AFMJ65 - 65"...
