L185 Diff Lock
/ L185 Diff Lock #1
njrqs
Queensland, Australia
Kubota L1-20 DT
The diff lock on my old L1501/L185 works OK but won't pop back off. It is apring loaded and should only work when pressed down.
But mine sticks on and I often have to reach down and pull it up with my hand.
Any ideas ??
Cheers
<font color=blue>Neil from OZ.</font color=blue> /w3tcompact/icons/smile.gif
/ L185 Diff Lock #2
Try spraying some penetrating oil around where the shaft goes into the trans case and work the pedal up and down. See if that frees it up.
/ L185 Diff Lock
Kubmech
So you don't expect there is any gear problem causing this, rather just a linkage ?
The linkage appears to right through the housing and pokes out the other side too.
Cheers
/ L185 Diff Lock #4
Neil, if the slippery stuff does'nt help, on the right side where the linkage attaches to the diff. lock rod that goes into the trans. housing you should see two flat pieces of spring steel. That's what returns the pedal. If they're broke or wore out just order: one 37150-2664-3 and one 37150-2666-0 and you should be like new.......Should be about 24.00 in OZ money..
/ L185 Diff Lock #5
neil; nice to have a kubmech around , ain't it. not only tells u what might be wrong with your tractor but also gives the part no.s. and the expected price!/w3tcompact/icons/smile.gif
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
2016 Komatsu WA320-8 Articulated Wheel Loader (A64553)
2016 Komatsu...
2000 STERLING T/A DAY CAB ROAD TRACTOR (A64278)
2000 STERLING T/A...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
REDDICK 3PT SPRAYER (A64278)
REDDICK 3PT...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
