L130 battery issue
/ L130 battery issue #11
I have the same problem - it does not charge the battery. My old G100 had the same battery for 6 years. It's a dry cell, so there's no water to add. Suggestions?
/ L130 battery issue #12
HOW DO YOU KNOW ITS YOUR VOLTAGE REGULATOR....
With the mower turned off, unplug the single wire coming off the voltage regulator, and check the voltage. Should be battery voltage. If not then there is a problem between the voltage regulator wire and the battery. Unplug the double connector off the voltage regulator, and start the mower.. with the engine running at full RPM, connect the leads to the two wires in the double connector coming out from underneath the blower housing, voltage will be AC, and should be in the range of 28-32 V. If those two test come out OK, then replace the voltage regulator.
If the voltage is low from the stator (wires coming out from underneath the blower housing) then you will need to replace the stator. It is under the flywheel.
MASSEY FERGUSON 4710 TRACTOR (A59823)
MASSEY FERGUSON...
2023 GMC Sierra Elevation Crew Cab 4x4 Pick-Up Truck (A60352)
2023 GMC Sierra...
1996 CATERPILLAR D6E CRAWLER DOZER (A62129)
1996 CATERPILLAR...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Deere 35G (A53317)
Deere 35G (A53317)
