L Series owners
   / L Series owners #221
Thank you. That size and engine appeals to me. Lots of power in a small package and not too heavy.
In that my tractor is new I have been going relatively easy on it for the first few hours. I ran it hard last weekend and pushed it to see what it could actually handle. I have to admit that the power it has is incredible. Pulling stumps, heavy loads and mowing deep grass. It never breathed hard. My 3130 would not have been able to handle without constant gear (GST) and throttle adjustments.
More impressed by the day.
   / L Series owners #222
My wife is expanding what she wants to do on our property. One of the things she is pushing for is livestock. She is also planting things all over the place. The problem I am running into is water. I have a solution worked out but am not sure my tractor is up to the task. I have a 2010 L3700. My grand scheme is to buy a heavy duty trailer frame off Craig痴 List. I have found what I am looking for, for about $150 to $400 and mount a 275gal tote to it. Add a 1 inch pump and some pluming and I should have a decent water wagon. No for the part that shows my ignorance. Water weighs in at about 8.5lbs per gallon. I use the number of 10lbs per gallon so I have a fudge factor for miscalculation. So I am looking at 2750 pounds of water plus the weight of the trailer, pump and pluming. The water is also a dynamic load. Is this setup going to be more than my L3700 can safely handle?
Any input is welcome.
   / L Series owners #223
Depends a bit on terrain, but I'd do it without issue. As an aside, just fill it half way if it's an issue.
   / L Series owners #224
It's mostly flat but there is one dry wash I have to cross.
I thought about the half way thing but I hate wasted space. I know it doesn't make scene but I know myself.
   / L Series owners #225
Unless the tank has baffles, and it won't, the water can slosh and cause problems like flipping you or the trailer over. Not a huge risk but a risk. The trailer can also drive a tractor and push you downhill or sideways on a slope.
On the flat ground of the Midwest, I would have no problem carefully hauling that amount of water slowly around the yard. I would be reluctant to go up or down a hill or slope. I have hauled lots of water with never an issue but I had more tractor weight. Go slow and work your way up.
I used 55 gallon plastic barrels and put a valve in the bottom of each. I could put three in my loader and hauled water that way. I also thought of the same setup on a trailer and the 55 gallons of water in each isn't likely to slosh around like a larger tank. Just my two cents here.
   / L Series owners #226
Thanks for the advice
   / L Series owners #227
I'm in an L 3940 and do a 500gal propane tank filled with water as a roller. Just as a reference point. More tractor, more water.
A pallet with a couple barrels and a carryall with a couple barrels might not be all bad either. Or a garden hose. Or a backhoe and some black pipe (this is the one that eventually will happen).
   / L Series owners #228
If you are going to spend money on a trailer and then a tank, why not just buy a 3 point sprayer tank which comes with a PTO sprayer pump. You can unhook the sprayed and use the pump to move the water where you want. I really don't think you would need a pump to fill stock tanks or water plants. The water pressure alone would do that. As far a pulling it do what is in your comfort level. Last summer I pulled a spreader with 5 tons of fertilzer in it up and steep incline with no problems, but I have been running tractors since I was 9 years old and I am 68 now. Just start out slow and get use to it but always keep in mind that something could happen if you don't think ahead
   / L Series owners #230
Seems most people here own a BX series Kubota.
Any L series owners here? I'm a first time tractor owner with a nearly new(13 hours when I bought it)L3200. Any advice or suggestions?
Suggest go to the TractorBYNet homepage, then narrow down to Kubota Owning and Operating, then put L3200 in the little search box in the upper right corner & search on that. While some are not really good matches, that turns up 468 threads. Just scanning thru the findings a large number of them are L- machines.
By the way, folks who rent a farm from me use an L4300 for misc hayfield work & some light bush hogging. They added wheel spacers in back for better stability/safety on steeper ground. Seems to be a workhouse & no problems with it.
Another by the way: How on earth do you find Kubotas with 13 hours on them? I would think a typical tractor on the lot at a dealer, being sold new, would have that many hours !!
Ford 8340 (A53317)
Ford 8340 (A53317)
12ft. S/A Utility Trailer (A56859)
12ft. S/A Utility...
2012 BMW 328i Coupe (A56859)
2012 BMW 328i...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
KSI Conveyor (A56436)
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
