l s xg3037
   / l s xg3037 #1
roostertale1
onaway mi
allis chalmers
I have a 2017 l s xg3037 that has been flawless since new. I just started having an issue with starting, when the key is turned to the glow plug position, I get nothing. The glow plug lamp doesn't come on and the fuel lift pump does not come on. After setting foe a bit with the key on the glow plug lamp comes on and the lift pump will start clicking. At this point it starts up and will run all day, Iam leaning towards a faulty relay.... any thoughts?
   / l s xg3037 #2
Consider having your battery load tested if it's original 5 year old battery? Might not be enough voltage to power up glow plugs right away?
   / l s xg3037 #3
If the battery is good it could be loose or corroded connections at the battery. Follow the ground lead to the frame and check there, too. From there you can try continuity testing on the various positions on the ignition switch.
2000 Witzco Challenger RG-50 48FT 50 Ton Tri-Axle RGN Lowboy Trailer (A52377)
2000 Witzco...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2016 Ford F-750 14FT Flatbed Truck (A52377)
2016 Ford F-750...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A52377)
2019 Chevrolet...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
