l s xg3037
   / l s xg3037 #1
roostertale1
onaway mi
allis chalmers
I have a 2017 l s xg3037 that has been flawless since new. I just started having an issue with starting, when the key is turned to the glow plug position, I get nothing. The glow plug lamp doesn't come on and the fuel lift pump does not come on. After setting foe a bit with the key on the glow plug lamp comes on and the lift pump will start clicking. At this point it starts up and will run all day, Iam leaning towards a faulty relay.... any thoughts?
   / l s xg3037 #2
Consider having your battery load tested if it's original 5 year old battery? Might not be enough voltage to power up glow plugs right away?
   / l s xg3037 #3
If the battery is good it could be loose or corroded connections at the battery. Follow the ground lead to the frame and check there, too. From there you can try continuity testing on the various positions on the ignition switch.
2019 ISUSZU NPR BOX TRUCK (A54607)
2019 ISUSZU NPR...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
