L 4150 will 4530b backhoe fit
   / L 4150 will 4530b backhoe fit #1
ou812jk
Ihave L 4150 tractor will a4530b backhoe fit or to small
   / L 4150 will 4530b backhoe fit #2
Go to the Kubota web site and click on Prior Products under tractors, then look up your model tractor. When you find it, there will be a tab for attachments that will list which backhoes fit your tractor.
   / L 4150 will 4530b backhoe fit #3
   / L 4150 will 4530b backhoe fit #4
You could use this backhoe on your tractor, but as others have said you could go with a larger one. I have a 4530b and use it on a L3300. It is fine for what I use it for. It really depends on what kind of work you plan on doing.
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
UNUSED HURRICANE MSC2020F ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
Hydraulic 80mm Quick Coupler (A52384)
Hydraulic 80mm...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
