L 4150 will 4530b backhoe fit
/ L 4150 will 4530b backhoe fit #1
ou812jk
Ihave L 4150 tractor will a4530b backhoe fit or to small
/ L 4150 will 4530b backhoe fit #2
Go to the Kubota web site and click on Prior Products under tractors, then look up your model tractor. When you find it, there will be a tab for attachments that will list which backhoes fit your tractor.
/ L 4150 will 4530b backhoe fit #3
/ L 4150 will 4530b backhoe fit #4
You could use this backhoe on your tractor, but as others have said you could go with a larger one. I have a 4530b and use it on a L3300. It is fine for what I use it for. It really depends on what kind of work you plan on doing.
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
2005 Ford F-350 Stakebody Flatbed Truck w/ Liftgate (A61573)
2005 Ford F-350...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2013 Infiniti JX35 AWD SUV (A61574)
2013 Infiniti JX35...
2026 Kearney 7'x20' Trailer (A64119)
2026 Kearney...
