L 3710 hand throttle stuck.
   / L 3710 hand throttle stuck. #1
George Schroeder
Bigelow, AR
Kubota L3710
Can anyone tell me how to get hand throttle loose and lubricate it?
   / L 3710 hand throttle stuck. #2
It's likely the bushing right below the lever. You can see it with a flashlight or in bright sunlight. Just follow the curvature of the lever and it's right below the plastic dashboard. Squirt some PB blaster down there and let it sit. If it's the cables. they can be freed, as well, but it is less enjoyable. Linkage is simple and all on the RH side of the machine.
Patience will lead to some movement, some movement will lead to full movement. Good luck.
Dear bspeedy. Your advice is greatly appreciated and it worked!!! It is really dark down in there and I needed help on where to squirt. Just 3 hours later it has loosened up and moves as easily and smoothly as ever. Before I read your post the man at NAPA had recommended new Liquid Wrench combination penetrating oil and lubricating oil spray can so I got it instead of PB blast. As my dad always used to say: your kindness will never be forgotten. Blessings on you! GS
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
2016 Ford F-550 4x4 Bucket Truck, VIN # 1FDUF5HT8GEB70191 (A51572)
2016 Ford F-550...
PALLET OF NEW HOLLAND PARTS (A51248)
PALLET OF NEW...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A51573)
New/Unused Gold...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
