L 3710 hand throttle stuck.
   / L 3710 hand throttle stuck. #1
George Schroeder
Bigelow, AR
Kubota L3710
Can anyone tell me how to get hand throttle loose and lubricate it?
   / L 3710 hand throttle stuck. #2
It's likely the bushing right below the lever. You can see it with a flashlight or in bright sunlight. Just follow the curvature of the lever and it's right below the plastic dashboard. Squirt some PB blaster down there and let it sit. If it's the cables. they can be freed, as well, but it is less enjoyable. Linkage is simple and all on the RH side of the machine.
Patience will lead to some movement, some movement will lead to full movement. Good luck.
Dear bspeedy. Your advice is greatly appreciated and it worked!!! It is really dark down in there and I needed help on where to squirt. Just 3 hours later it has loosened up and moves as easily and smoothly as ever. Before I read your post the man at NAPA had recommended new Liquid Wrench combination penetrating oil and lubricating oil spray can so I got it instead of PB blast. As my dad always used to say: your kindness will never be forgotten. Blessings on you! GS
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2022 John Deere 8R 310 MFWD Tractor (A53342)
2022 John Deere 8R...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
