Tires L-3130-HST right tire wear on outside. front axle problem.
   / L-3130-HST right tire wear on outside. front axle problem. #22
It's not 2". Attached is a shot of the toe-in adjustment spec from the L3130 manual.
attachment.php
At 2 inches your tires will not last very long... the outside edge of one will grind off...
Are you sure it isn't 2 cm ?? Even that is a LOT for use on hard surfaces... KennyV
I will call the dealer monday to find out what they say.
Thanks
attachment.php
AH HAH!!!! That's it!!! I read it wrong...I forgot Kubota is foreign!!!
Thanks everybody for all your help....I think we nailed it down, now I can buy some new tires!!! OH Boy!!!DUHH!!!:ashamed:
   / L-3130-HST right tire wear on outside. front axle problem. #26
   / L-3130-HST right tire wear on outside. front axle problem. #27
Well ... at least you didn't go for the 8 side of the (2 to 8 mm) and set it at 8 inches toe in... that may have required you to use the rear wheel lock to move forward...
Glad you are soon to be in a much better handling and steering tractor... KennyV
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
10' Feed Bunk (A50515)
2007 CATERPILLAR 257B SKID STEER (A51242)
2007 CATERPILLAR...
2007 Toyota Camry (A50324)
2007 Toyota Camry...
