Tires L-3130-HST right tire wear on outside. front axle problem.
   / L-3130-HST right tire wear on outside. front axle problem. #22
It's not 2". Attached is a shot of the toe-in adjustment spec from the L3130 manual.
attachment.php
At 2 inches your tires will not last very long... the outside edge of one will grind off...
Are you sure it isn't 2 cm ?? Even that is a LOT for use on hard surfaces... KennyV
I will call the dealer monday to find out what they say.
Thanks
attachment.php
AH HAH!!!! That's it!!! I read it wrong...I forgot Kubota is foreign!!!
Thanks everybody for all your help....I think we nailed it down, now I can buy some new tires!!! OH Boy!!!DUHH!!!:ashamed:
   / L-3130-HST right tire wear on outside. front axle problem. #26
   / L-3130-HST right tire wear on outside. front axle problem. #27
Well ... at least you didn't go for the 8 side of the (2 to 8 mm) and set it at 8 inches toe in... that may have required you to use the rear wheel lock to move forward...
Glad you are soon to be in a much better handling and steering tractor... KennyV
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
DIRT DOG RT205 60" (5') ROTARY TILLER (A51243)
DIRT DOG RT205 60"...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
