L 2900 won't shut off
/ L 2900 won't shut off #1
dkshooter
when I shut off the tractor (with the key) the tractor wont shut down I have to pull the manual shut off can anyone tell me what part/solinoid needs replaced?
/ L 2900 won't shut off #2
sounds like the fuel shutoff solinoid has went bad. If it is not making the loud click sound when you cut the key on then most likely it is bad..
/ L 2900 won't shut off #3
before you pull the solenoid off check that you have 12v at solenoid if you do then you pull the solenoid part#15471-60010 just get the dealer to check that is the right part # for your s/n
